jFF_Bulbo
Hello AK'ers.
I´m working on a AU-7900.
before the recep: No short on DBT, no relay click
After recap: No short on DBT, no relay click
I recaped F2596 board, all 'litycs are new.
All output transistors are new's, On Semi 93g/94g installed.
Transistors TR601, 602, 603, 605 & 605 are new. Relay also new.
All VD1212 diodes replaced with 2x4148
Diff transistors A798 replaced with KSA992....
Well... there is no relay click. on the collectos of TR03 i have 44volts (conected to DBT...) is should be 24v.
The voltage on differencial is about 44 volts (shold be 0.6v according SM)
The bias work well a few seconds... it is about 17mv (with DBT) but then it downs to zero, both channels.....
I don´t know what can be......
i post some pics, maybe someone can see something i missed. Thank you for your help.
