petehall347
the brandy coffee man
diodes in lots of cases go short . maybe it has a bad connection ? it needs some simple testing to see if its open or shorted . a bad ground would make for this condition .
No they're not, look at the spec. Also depends on the definition of slow.I just did some searching and found a couple threads where EW states that the 15015,16 are “slow” transistors.
RELAY IS WORKIG!!!!!!!!!!!
when i conected the "2" terminal the relay just Click!!!!
Is this normal??? I'm worried.....
For this amplifier they are not slow.
For an AU-X1 they are slow.
It sounds amazing.... I'm interested. I'll Pm You.If you really want to replace your 2SA798 you need this https://www.mouser.com/ProductDetail/757-HN4A06JTE85LF & my adapter. If interested PM me and i will send to you pair of adapters for free. But you will need to solder smd component to it (chip i supplied the link to is Toshiba smd). it is matched and hfe for the one 's i got is between 400 to 500+
Sure.It sounds amazing.... I'm interested. I'll Pm You.
Regards
The KSC1815 might not have enough gain. Depends on the application, if its available gain will be enough. Probably no harm in trying it out, though.Hello again.
Recap is going well. Bias & dc offet are working properly.
Left channel sounds horrible... The suspect is a C1313 transistor.
I don't have KSC1845 (mouser, Newark & digikey ran out of stock...)
BUT i have KSC1815.
Are the 1815 good subs for the c1313???
Regards.
Can you actually hear the difference from a transistor with fT 4Mhz and one with fT 8Mhz providing all other components are the same? Is the difference in sound good or bad?I do not understand why you keep changing components which are not faulty.
Replacing a 2SA798 with 2 separate KSA992 is not a good substitute although it will work if you have no other option.
A handheld transistor tester does not give an accurate HFE reading, you need to do it properly with full operating voltage and a curve tracer.
The 2SA798 is thermally coupled together, this means the gain tracks perfectly as the heat changes. Two separate transistors cannot do this.
If the 2SA798 is not faulty, put it back in.
The MJ21193/94 as I have already said is not a good replacement for the original transistors, they have less than half the bandwidth (ft) then the originals, this does change the sound.
You want to use MJ15015G and MJ15016G, 6mhz and 18mhz respectively.
These will give closer performance to the original transistors.
The reason you see 44V on the relay coil is because the relay is not on, when the relay is turned on then there will be 24V on the coil.
You are seeing 30V on the output because there may be an imbalance in the power supply to the front end of the driver circuit which is too great to equalise with the DC offset adjustment.
You need to print the schematic, get yourself a highlighter, and verify all voltages are correct. When you find something is not right, then you can investigate that part of the circuit.
You need to stop pulling components and swapping things because eventually you are going to damage the circuit board traces and you are going to then have bigger problems.
Let us know how you get on.
Some people say they can hear a difference. For the AU-7900 and the relatively small fT difference I think most would be hard pressed to notice. However, amplifiers with much higher fT original fit OP transistors (and drivers for that matter), the difference is easier to hear. I would characterise the audible difference as a slight reduction in the rendering of micro detail, in other words affecting the higher frequencies - it is very subtle.Can you actually hear the difference from a transistor with fT 4Mhz and one with fT 8Mhz providing all other components are the same? Is the difference in sound good or bad?
