Chriswashere
Hey all, it has been a while since I posted. As per my usual disclosure I do this as a hobby and have been messing around for maybe 10ish years, but my lingo and understanding of some things is not the best so please stick with me.
Anyways, I have had this Sansui au-888 for about 5 years now give or take, and it has an issue I haven't been able to solve. Every blue moon this unit would suddenly violently crackle, sounding like normal crackling and then developing to thunder. I'd shoot up and power it down, first turning off the speakers since the noise would keep going until the amp ran out of juice. Doing research I found out that Sansui has a transistor problem with the CDC8002 and CDC9002 transistors known as "flying saucers" or "soup cans". No big deal! I went through both amp boards and the preamp (I believe, but it has been a while). And swapped out every soup can I saw. I did mess this up and there is a thread floating around about this, but that is not important as I sorted that.
Replacing these transistors seemed to do the trick, but apparently not. A few months ago the unit did this again, and blew fuse F003 as is tradition, so I set it in my dads stereo cabinet and moved on. After a few months of sitting we get to today. As usual I put in a new fuse but decided to put it on a variac set to 100V (should have done lower), and I turned it on. Immediately smoke poured out of the left channel so I shut it down.
I have pulled things apart and have found that F003, F005, and the left speaker fuse are all blown. On the driver board R825 was burned but all surrounding parts seemed to test fine, same with the 2sc111 transistors. Using a hickok transistor/diode tester I did poke every transistor and diode but found nothing that was a dead giveaway, but on the protection board there were 2 soup can transistors I missed (and now replaced), but the main concern is what caused this. Does anyone have any recommendations/ suggestions on what to do and what parts or areas to check that I may be overlooking? I was thinking of pulling the driver boards and output transistors and taking the voltage of each connector pin (not at full voltage though) and seeing whats what.
I also recapped f-1293 just because I had it out thinking the problem was there. Both transistors tested good in and out of circuit.
It's time to wrap this thing up so any help would be appreciated. This is one of those "keeper" units due to the long track history of messing up. I may be slow at responding due to other projects but will try my best.
