vuman
Hello Team,
I need you help to identify the issue in one of my F-2029-1 driver card that when bad after upgrade capacitors and transistors.
I upgraded in two stages, first all power capacitors on F-2030-1, F-2019, and F-2029-1. All worked well and the sound improved substantially.
Then, recently I got more parts with KSA992 and more capacitors for F-2019 preamp. After replaced capacitors and transistors, the relay will not kick in.
I identified one of the F-2029-1 went bad, I swap the two cards from L to R and R to L. With one good card alone, the relay kicked in, if plug in the bad card, the relay will not click.
In troubleshooting,
- I took out all transistors and tested NPN, PNP, they are all good.
- TR801/803 were replaced with KSA992
- VR801/803 were replaced with bourns cermet 5K and 200ohm respectedly
- replaced C801 with same value 2.2uf 50v
- replaced C815/817 with 220uf 80v
- replaced C807 with 220uf 16v BP
- took out 2SA483 PNP tested good
- took out 2SC783 NPN tested good
- took out 2SA706 PNP tested good
- took out 2SC1124 NPN tested good
- took out 2SC983 NPN tested good
What else can I check, please help to identify the issue. I am greatly appreciate.
Thanks
In troubleshooting,
Thanks
