Removed the Tone boards F-2575/F-2576 and desoldered ecaps & transistors. Did some testing and the caps appear fine, but with some
very low ESR values. The 47 microF reads below 1 and the 3.3 microF reads between 2 and 3. As I understand low is good.
For the transistor 2SC1708, HFE values for 3 are under 500 (spec. min.) at between 460 and 470. There is only 1 over 500.
For the 2SA798, the ones from the F-2576 board HFE values read between 288 (low) to 366 (high). Spec. min. is 250.
For the F-2575 board HFE values read between 510 (low) to 553 (high). All reading were taken with a Peak Atlas DCA55 tester.
I realize these are far from perfect tests, as I am not at rated voltages, but typically the Atlas has served me well in the past.
Anyone seen similar readings or should there be more dramatic differences?
