Happy Holidays everyone;
I rarely reach out for help however, I have reached a point where I need some input from the experts.
This is my 1st time working on an X balanced circuit and I am very perplexed about this situation.
The amp is in protection, all outputs are good and I am able to adjust the 0vdc for the Equalizer Amp and Tone Control Amp, no problem.
I am able to adjust the Hot/Cold Balance but when I try to adjust Center DC 0v, the adjustment pot seems to have no effect...symptom is the same on both channels...I am getting -26v.
I am able to adjust bias ok.
Here is the weird thing and where this design has stumped me...When I measure the main rails they are not balanced despite the delta being about 70vdc, I measure -30v and +41v. They should be equal at about +-36vdc.
This is the same on both sides of the amp.
All 4 main rail caps are new/good.
Looking at one side for instance, circuit bd 4267, my voltages on the front side seem to be correct but on the back end I am reading the following incorrect values...pin18 = -28v, pin 16 = -24v, pin 13 and 14 = -26v, pin17 = -28v, pin 15 = -24v.
I am stuck with the Chicken or the egg...are these values off because the main rail or is the circuit causing the imbalance on the main rails?
I also measured the resistors that create the artificial ground and they are ok.
I know there are a few people here like Leesonic, Hyperion and Bunpalump that probably have the experience to help point me in the right direction and hoping they may be able to chime in.
Thanks to anyone that can offer insight!
Paul
Paul
