p4spooky
Acquired a non working AU-D55X for the price of a lunch at McDonalds
Not a lot of talk here on this model, found couple of useful threads HERE and HERE (incomplete thread). Although this was released around 1983, I was intrigued by the "Super Feed Forward" circuit and its impact on the distortion and possibly sound. Also like the form factor, similar to AU 317 (which have restored and love the sound). Wanted to get this one going to see how this compares to the AU 317 in particular.
It was clearly sold as a non working unit "No power". Opened it up and did a through visual inspection. Missing main fuse which is never a good sign. Luckily this model does have a removable bottom cover. Three output transistors blown, NPN on the right channel survived.. Started with my meter and the service manual and checked all transistors on the left channel along with diodes and fusible resistors. Interestingly all fusible resistors measured perfect although I found catastrophic damage to the transistors on the left channel. Right channel appeared OK except for a shorted PNP output.
Showing left channel damage. Used the right channel from SM as left channel is busy with values and audio path marked by Sansui.
I did not catch the FET failure on the left channel during initial check. If you notice KQ1 and KQ2 survived along with its current source KQ3 so I assumed the FET should be OK. Read on as I found out later that the FET was indeed damaged.
Initial observations and decision to scrap or move forward
1. The amplifier circuit is split across two boards F3975 and F3976
2. The bias transistor KQ8 is installed on F3976 with ribbon cables going everywhere
3. F3975 is partially blocked by F3982 (Input selector and Muting) board
4. Non standard relay AP2U (24V)
5. Power supply/Protection and Multivibrator circuits F3989 mounted vertically on F3976
6. Regulated power supply on F3976 (+-20/+-22V) with positive rail running HOT
7. The best way to work on this was a complete disassembly IMO.
8. Decided to do a FULL restoration while I had all the boards out provided the main transformer was not shorted.
