Wise words.. will get onto it now and report back
These voltages are on the collectors of those transistors, with reference to ground (chassis)? with the unit not on DBT ?Tr607 is +56.5v
Tr608 -56.4v
This is directly across the zener with power applied and unit not on DBT ?Zd-602 580mv…
Please clarify.
There's your problem, the zener is faulty - it's behaving like an ordinary diode (or it is polarity reversed!), which is wrong, you need a 400mW or 500mW 13V zener as a replacement. (for polarity, the marked end of the diode should go to the 'fatter' trace (i.e. ground) on the board).The zener diode continues to have 580mv
Ok, now you need to remove and test those four transistors I listed.I replaced the zener diode with a 13v 500mv it measures the same in circuitno change
A missing ground perhaps? - put an ohm meter on the ground trace of the PSU board and check that it is connected to the chassis, or any of the transformer secondary winding centre taps.I’m starting to think is it possible there’s an issue with the board the filter caps screw to?
So just to firm up on a few facts.
This regulator with replaced semiconductors has actually worked OK at some point? i.e. Have you checked the pinouts of the replacements IF the regulator hasn't worked since the transistor changes -
the symptoms are the same before and after the change - I did not check the original voltages, the pin out can’t be wrong as it’s mounted to the heatsink. The originals were heat stressed but tested well with my transistor tester. The new ones have never worked any better than the old ones from what I can tell.
When did it stop working? - what operations have you performed on this regulator which might be relevant? Stopped working around November initially I thought the speaker was faulty but when I swapped amps out I realised it was the sansui at fault the distortion is worse as you increase volume I will test more voltages tomorrow
Have you actually checked all the transistors in the negative regulator, I know you replaced two, but what about the others? I checked them all they are new and test good I followed the board for pin out implementation I can take more photos if needed
If all of the above has been done, and we have eliminated missing grounds or other wiring faults, we are down to weird faults like leaky/shorted capacitors or open resistors - you have checked R621 (10Ω) & R622 (10Ω) recently? These are fuse resistors they are testing well and were replaced manual says 470 ohm schematic says 10 ohm I fitted 10ohm.
The zener diodes you are using, are you sure they are zeners? - what is the type number written on the diodes themselves? - i.e. NOT from the supplier delivery note. I am sure these are correct the previous one which I replaced worked fine for years and new one installed is bzx55b-13-tr 13v zener 500mv 2 percent tolerance
Assumption.
I am working on the assumption that as the negative regulator has the voltage reference in it (the zener) that it has to work before the positive regulator will come up, so I have limited my attention accordingly.
