Hi AK members,
Got a unique problem with a Sansui BA-F1 amp.
I got it with the left channel blown for repair. Found outputs and drivers bad. Also R37, R42 burnt I replaced all the obvious bad components and powered up the amp. No issues and protect was off.
I adjusted the DC offset and bias. All was going well. I went to check power and distortion and R42, a 47 ohm resistor began to smoke at about 1/3 power. I shut down and rechecked outputs and drivers. All still good.
Unit still powers up not in protection, but when I up the level for output on left channel the R42, 47 ohm will heat up and burn if level not turned down.
I have compared the LC to RC and see that the DC voltages listed on the schematic for the left channel change with the output level control. They do not change on the right channel. I have now recapped the driver board, pulled a number of transistors and can find nothing at fault. Yet, I cannot increase level without resistor burn.
I attached a copy of amp schematic. Voltages at TR10 and TR11 emitter and base remain constant while increasing level. The voltages at collectors start correct with no output level on front panel. When I increase the audio level with front panel control the DC level at collectors increase, This dose not happen on the right channel. The DC values remain constant.
If anyone has a good theory why this might be happening, would appreciate the help.
