Thank you Hyperion,
Puzzle solved.
Appears after all the parts replaced there was a major change in the previous bias setting. It was so great that trying to make the adjustment at the factory location I didn't feel confidant in making such an adjustment. I did it in steps comparing to the remaining working channel.
After getting the bias on bad channel transistor outputs to match the good channel, I went back and did the measurement at the factory location again and it worked.
Thanks you for all your input, experience and taking the time to respond.
Another amp rescue from the past back into use.
Rick
Puzzle solved.
Rick
