dr*audio
Fish fingers and custard!
The basic trick to this type of troubleshooting for a noise source, is to start at the input of the circuit and work towards the output. You can't short the DC path or you will turn the transistor off, or blow something up, so you short points that are AC coupled by a cap, or you use a 10uF cap to short to ground instead of a wire. When you find a place that shorting it out kills the noise, the source of the noise is on the input side of the short.
