And is the noise gone?
in any case, replace C7037 and C7038 with non - polarized caps. If you can fit a polyester film cap in there, use that. If not, use non polar electrolytics.
Noise is gone.
I just happened to have some Bennic Metalized Polypropylene that I guess I never got around to installing on some other project,
http://www.mcmelectronics.com/product/50-4545. There is room.
I'll tidy it up a bit, this was a trial install.
Things seem great. Noise gone and so are the pops on the filters ON/OFF.
The wild part is that I "guessed" at those caps, way back when.
http://www.audiokarma.org/forums/showthread.php?t=371489
You can see I didn't get any attention at that time. Wrong forum? I tend to surf the whole site, but I see it helps to target certain groups.
From what I could find, the solid aluminum caps are never suspects. I found info in AK from reputable posters that says those don't get bad so leave them alone. AND for BOTH to be bad. What a puzzle!
You guys have been great! I can't thank you enough. I gave up a few times on this thing and took it off the bench. Karma all around.
AND, I got this old scope out and checked the tubes and learned how to use it.
Now, if I can learn that "Classic Half-Split Troubleshooting" trick. (In computer science, we call it Binary Search or Divide and Conquer).
OK, now to check the amp adjustments. With the noise in there, it seemed impossible to check those. AND, to find all the case parts...jeez this has been apart a LONG time.
