Dont worry about TR20, forget it for the moment until you have the amplifier running, as I said several posts back, all this transistor does is turn on when there is DC on the output and activate the protection circuit....
You can take it out if the amplifier for now, its not the problem....
But do NOT connect the amplifier to a speaker until it is running correctly.
The transistors which affect bias are TR06, 08, 10 and TR16, 18 which are the drivers. Tr601, 602 which are the output transistors.
Also the STV-3H diode which regulates the bias current by thermally tracking the heat of the output transistors.
The surrounding resistors are also contributors to lack of or no bias current....
These are R36, R40. R52,R54. R60, R66. And R38 which is a current limiter for the bias circuit, these can go open when the amplifier has been subject to excess bias current.
I recommend replacing the bias and DC offset trimmers with multi-turn bournes trimmers.
The Alps trimmers in there are prone to failure because of their age......
