kevzep
Its all about the Music
there seems to be a very bad error in the manual ..it would end up having 15 amps on the outputs setting the bias the way they are saying in the manual .it should be 10ma . i will start a thread about it . maybe this has been corrected in the past .
You want 3.3mV........
There are test points for setting the bias, one is on the component side and the other is on the trace side.
Its pretty clearly marked in the SM but they say they are both on the component side which is wrong.
I will try to find the thread where this was discussed and there are also pictures.
