JRH99
I have a G-7500 running a pair of Ditton 44 speakers and it sounds fantastic! I purchased the G-7500 about 6 months ago and it has be working great with daily use. Last weekend I decided to detox the switches and potentiometer's as they were overdue for a cleaning. The first thing I noticed when I took the cover off was that the voltage selector was set to 230V, not 110V. The unit does have the 230V sticker on the back, but has the standard 2 prong US type power cord.
So here are my questions:
Thanks!
- Should I switch it to 110V? The reason this is even a question for me is that the units sounds amazing to me as it is. I suspect it was never switched to 110V and has been running at 230V on 110V for the past 40 years. I'm concerned if it might create any issues by switching it now.
- What is the impact of running at 230V on the 110V? I understand it will have less power and the display lights might be dim. But is there harm in running it this way? Could there be any benefit to the longevity of the unit running at the lower power?
- What type of fuse do I need to use if I do make the switch to 110? I have searched this forum and all over the net to find the answer to this question. Mainly, should it be a fast or slow blow fuse? The service manual does not state which to use. This may be a dumb newbie question, but it seems this would be critical and I can find no definitive answer on it. I have determined that I need a 7A fuse based on the sticker that was placed on the F-2980 power driver board next to the F-604 fuse location. It states a 7A is needed at 100/120V and a 4A for 220/240V. The service manual states 5A is needed at 100/120V and a 2.5A for 220/240V. The current fuse is a 4A 125V.
Thanks!
