Hello,
I have a G7500 that is in need of help. The unit will not power up or produce any sound (meter lights still turns on and the tuner appears to be working) so I pulled off the cover and after blowing out 40 years of dust I gave it a quick visual inspection. There is alot of brown goo stuff around the cluster of caps near the relay. It almost looks like the glue has corroded some of the resistors/caps and wiring in that area. Im not sure if that was what did my amp in or its just superficial but my intent is to clean it all off. The resistor that is burnt and R36 and is charred beyond being able to tell what colour bands it has but it looks to start with orange and end with gold. R78 which is one of the 5w.33ohm resistors is open circuit but the other 3 are testing good. The board itself appears to be unharmed. I cant see anything else that looks bad but havent metered out everything on that board yet.
from my research repairing this particular board may be over my head but I would like to give it a try. Ive tried to track down the parts I need but have not come up with anything solid. I was hoping for some guidance on the repair or if someone feel like a challenge I could always send out the board. Thanks
David
David
