goodshelac
Member
Good Morning! I need a little help getting my G-8000 to power on. Last night I was adjusting DC offset on the left channel which I did no problem. I went to connect my leads from my DMM to adjust the bias and I must have connected to the wrong test point. When I connected my negative lead there was a spark and the amp went dead. There was also a little smoke coming from under board F-2806. I didn't see a fuse that was blown. Is there a fuse hidden somewhere that may have blown? What would be the most likely culprit here? Thank you!!
