The tuner in this receiver had issues but now functions.
The first issue I had was that the local oscillator variable cap. did nothing and the dial was way out of whack. The digital display was way off too. After replacing the variable cap. and tuning it to proper DIAL setting, it worked OK, with the multiplex light and center frequency display lighting up, as well as signal strength.
The next issue I've found and cannot fix is that the DIGITAL display is off by about 200KHz,(0.2MHz). When a known station is tuned, regardless of the dial calibration, the digital display is off 0.2MHz! Also the servo lock LED does not light up. The manual says nothing of the digital display, and there are no adjustments listed in the manual. There is a crystal and another variable cap. on the digital display board, but it does not seem to affect the frequency read out at all. My head is getting bloody from banging it against the wall : )
Any comments or ideas would be appreciated.
