Sansui G6700 protection Relay
josumo1
Does anyone out there have a suggestion for a 323DO24 protection relay that can be had from Mouser/ Digikey? Thanks, much appreciated.
so it is fujitsu (they are still in business), a 24v coil, have to check if it is dpdt/4pdt, looks to be 2pdt, need to determine the pinout and lead spacing, then check mouser and digikey.
Good question. Why do you want to replace it? It looks like it's going to be a hard relay to find.
- Pete
The cover on the relay snaps off and is removable
Just get in there with some cleaner and check the contacts.
Yes, but I wouldn't go in to clean the contacts unless there was a good reason to do so. That is not "normal" maintenance.
If the contacts are suspected dirty, if they don't clean up by simply drawing a piece of DeOxit soaked card between them, and if there is any sign of contact 'pitting' then forget it, you need a new relay.
IMHO the main thing you need to do is to determine what the original problem is. I'd hate to see you track down a replacement relay, only to find that it did not fix your problem.
Can you give us a list of your original symptoms? Also need to know of any repairs you may have tried, and the results.
