Aloha Sansui Aficionados![]()
SANSUI AU-5500 Specifications Sansui
Here what I found
AU-22 STK016
AU-2200 STK016
AU-3300 NEC D188A B545A TO-3
AU-3500 NEC D188A B545A TO-3
AU-1100 TO-66
AU-1500 B509D TO-66
AU-3900 sanyo B509D TO-66
AU-4400 2sc1444 TO-66
attached missing AU-33 in the list
use the Sanken 2SC1444
Build to last
In 1974
AlohaIt looks like it's in there near the start of the list in 1974. Great to see some live-action pictures!
--- SECOND GENERATION ---
1972 AU-6500 30 watts
1972 AU-7500 32 watts
1972 AU-9500 75 watts
1973 AU-8500 60 watts
1973 QA-7000 12 watts (QUAD)
1974 AU-22 13 watts (JDM)
1974 AU-33 20 watts (JDM)
1974 AU-2200 10 watts
1974 AU-4400 20 watts
1974 AU-5500 35 watts
1974 AU-6600 42 watts
1974 AU-7700 54 watts
AU-33 = AU-4400?
Where does the AU-G99X fit in here? Or is it too late of a model? I have one and think it’s a real peach.
I am pretty sure the AU-D11 II isn't a feed forward design, everything else, i.e. DC-DD, GF, X-Balanced, just not SFF.![]()
Very impressive amount of work and dedication has undoubtable gone into researching all this info. And it very much appreciated by me, as I am new to this game and searching for a Sansui amp to buy. But in doing my searching and learning, I have run across articles and YouTube videos mentioning particular known problems with certain models. Is there any sites available out there that lists by model the known problems of each of the amps. I know I'm probably asking for to much, but just hoping. I have learned that some amps (not necessarily Sansui) are to be avoided because certain replacement parts cannot be sourced, or at least any available replacements are cheap Chinese knock offs. It would be nice to have this type of info at hand before jumping into a bottomless pit.
Thank you for your reply. I was considering that particular amp, but have read that the glue used on their boards was a problem and needed to be removed. I don't know if this is accurate or not.No such comprehensive list exists. There is no Sansui amp I would avoid, there are workarounds for the handful of Sansui amps that contain parts no longer in production, and plenty of community her to find originals through. Your best bet is to post in the forum if you have a Sansui in mind. If you don't have a Sansui in mind yet, I would recommend the AU-717 as a strong entry point into the brand, and maybe the last Sansui you'll ever need.
