Sansui production numbers?
tobyj17
Comfortably Numb
Is there a source for Sansui production numbers? like 10,000 G-8000's built...etc. I can't find anything on the internet, and can't seem to find anything here on AK. Ideas?
The best way to estimate the production volume for a particular model is by looking at the serial numbers recorded in the Sansui Database. Sansui used a very consistant code.
First two digits are the production line, the next digit is the year, next two the month and then the last four are a sequential count of units produced on that production line that month.
In some case, the line may be dedicated to a particular model if the production was high enough. In other cases, multiple models were built on the same line in the same month. With a little detective work in the database you can get an idea of numbers produced. I've never seen an actual Sansui document that listed production numbers.
- Pete
The only figures I have are montly production of amps and speakers. I guess you did not think it would be so many
See pic
That's all models for all markets. It probably trippled or more before the decline at the end of the decade.
- Pete
- Pete
True, and one has to consider all the different models Sansui offered from straight amps to receivers. If you look at it that way, it isn't really a lot for each model.
I guess what I was most interested in were the monster receivers, like G-8000 and up. It would be interesting to know how many were manufactured back then to how many still exist today.
