Here's a visual aid!
See how it blocks the U spaces above and below it? Not cool.![]()
No it won't be, if you a trying to have the equipment one above the other with no gaps for ventilation.
right. duly noted.
It's just kind of silly that it is sooo close to being correct, could easily have been designed to be compatible, but just isn't. It's the "pretend" aspect that's frustrating. I accept not all gear will rack mount - it's an odd need for the vast majority. But then don't tease!
I think the pioneer spec series is compliant. Some Nikko stuff I saw too looked correct. Sansui tricked me...Even if not "professional," it's high-end enough to warrant some seriousness in the accessories dept. I can't imagine any company doing something like this today.
Those are in homemade racks or sansui branded ones. The maker of my rack is irrelevant. It's Middle Atlantic - but doesn't matter. It's a standard! That's like asking the brand of railroad tracks.Many are in racks, many do not have issues. You do and your rack witch in this thread have failed to mention the maker.
Commotion were? It's your thread you started it for whatever reason. Then when others respond there all wrong but you.
You just have to trust me that there's something called a 19" rack standard that's been in use since before sansui imported stereo equipment. I can't keep repeating this point. I want to cry because no one seems capable of understanding this. It's basic.Your the one buying something thats 40 years old and when it doesn't fit your new rack perfectly you want to stomp around and cry about it lol.
link? Did it end with "Naw, they fit fine in racks!"You must have not did your research very well. Someone posted this same topic about 40 days ago although they did a lot less crying about it.
All that said looking at your rack and the mount it fits. It block the next hole up from it and should for a substantial mount. The problem is your rack and the lack of mounting holes. One should have a continuous hole pattern like the two close holes the full length of the rack.
In closing...I want to educate potential users on this rack issue. You guys can get all defensive about your brand, etc, but that seems silly to me.
Sansui does not mount properly on standard 19" rack systems. Case Closed.
Again, the design never had standard racks in mind - the rack ears are designed to suit the Sansui OEM racks only. They never 'pretended' or claimed to be anything other than this.
The only point of contention is that Sansui were somehow inept due to not adopting a universal rack ear design for their consumer-grade gear which is designed to suit Sansui-specific racks. We obviously disagree on this point, and so bet it.
The main thing to take from this thread is your last sentence quite above. :thmbsp:
Well, now it is obvious to me they certainly did design it specifically for their consumer grade rack. So they could sell their consumer grade racks. Hey - I know the bottom line is the bottom line, but that's still gonna get an eye roll from me even 40 years later.![]()
