The below is the BOM for all the electrolytic caps, trimpots, diodes, and transistors that I used to make my Mouser orders are below. Don't expect them to be perfect as I haven't finished and double-checked the list.
Board Component Type Subtype Value Voltage Amps Mouser PN Qty Notes
After Driver Board C006 capacitor electrolytic 100 uF 100V Axial 647-TVX2A101MCD 1
After Driver Board capacitor electrolytic 0.1 uF 250 V Axial 667-ECQ-E2104KB 2
AM board capacitor electrolytic 10 uF 16V 1
AM board capacitor electrolytic 100 uF 16V 1
AM board capacitor electrolytic 3.3 uF 25V 505-MKS2B043301H00KI 2
AM board capacitor electrolytic 4.7 uF 25V 1
AM board capacitor electrolytic 33 uF 16V 1
Driver (two of them) C802 Capacitor Electrolytic 100 uF 10V 25v 647-UKL1V101MPDANATD 4
Driver (two of them) C804 Capacitor Electrolytic 220 uF 10V 647-UKL1V221KPD 4
Driver (two of them) C805 Capacitor Electrolytic 4.7 uF 50V 647-UKL1H4R7MDDANA 4
Driver (two of them) C806 Capacitor Electrolytic 3.3 uF 25V 647-UKL1H3R3MDD1TA 4
Driver (two of them) C807 Capacitor Electrolytic 100 uF 50V 647-UKL1H101MPD 4
Driver (two of them) C809 Capacitor Electrolytic 470 uF 6V 647-UKL1V471KHD 4
Driver (two of them) VR801 Resistor Trimpot 100K 652-3352H-1-104LF 4
Driver (two of them) VR802 Resistor Trimpot 1K 652-3352H-1-102LF 4
Driver (two of them) TR801 Transistor BJT 2sc711 (E or F) KSC945CG 4 CG C for ECB pinout and G hFE gain of 300 or so
Driver (two of them) TR802 Transistor BJT 2sc817R (F) KSC1845F 4
Driver (two of them) TR803 Transistor BJT 2sc627 (3) ZTX696 4 Will need a TO-92 heatsink
Driver (two of them) TR803 heatsink Transistor BJT 2sc627 (3) 532-575200B00 4 TO-92 heatsink for ZTX696
Driver (two of them) TR804 Transistor BJT 2SC984 C KSC2690A or KSC2383 4
Driver (two of them) TR805 Transistor BJT 2SC680 (B) MJE15032G 4
Driver (two of them) TR806 Transistor BJT 2SA566 (B) MJE15033G 4
Driver (two of them) hanging underneath C813,C814 Capacitor Electrolytic 0.1 uF 250V 647-UVY2D0R1MED 4
FM IF board C215,C233 capacitor electrolytic 10 uF 25V 2
FM IF board C227 capacitor electrolytic 3.3 uF 50V 505-MKS2B043301H00KI 1
FM IF board C230 capacitor electrolytic 47 uF 16V 1
FM MPX board C402,C407,C416,C417,C419,C420,C429 capacitor electrolytic 10 uF 25V 7
FM MPX board C406,C434 capacitor electrolytic 1 uF 50V 505-MKS2C041001FKI00 2
FM MPX board C428 capacitor electrolytic 0.68 uF 25V 505-MKS2C036801EKF00 1
FM MPX board C433 capacitor electrolytic 47 uF 35V 1
FM MPX board C435 capacitor electrolytic 1 uF 25V 505-MKS2C041001FKI00 1
On bridge Transistor BJT 2SC627 512-TIP48TU 1
Other D001 Bridge DS10BN-M 583-BR84 1
Other C003 capacitor electrolytic 220 uF 10V 647-UPW1E221MPD 1
Other C004 capacitor electrolytic 1000 uF 50V Radial 1in diameter 647-UPW1H102MHD 1
Other C005 Capacitor Electrolytic 3300 uF 100 V 647-LLS2A472MELC 1
Other C005 capacitor electrolytic 3300 uF 100V 647-LLS2A472MELC 1
Other C811,C812 Capacitor Electrolytic 2200 uF 80 V 647-LKG1K222MESCBK 2
Other C811,C812 capacitor electrolytic 2200 uF 80V 647-LKG1K222MESCBK 2
Other D002 Diode SR1FM2 100V 3A 625-UF5401-E3 1
Other TR807-TR810 Transistor Output 2SC1116 (R, O or Y) 863-MJ15024G 4
Power and Protection Block C011,C012,C017 Capacitor Electrolytic 220 uF 50V 647-UPW1H221MPD6 3
Power and Protection Block C017 Capacitor Electrolytic 220 uF 25V 647-UPW1H221MPD6 1
Power and Protection Block C901,C902 Capacitor Electrolytic 1 uF 50V 647-UFW1H010MDD 2
Power and Protection Block D010 Diode Zener ZBI-12 12V 1W 78-1N4742A 1
Power and Protection Block D011 Diode Zener ZBI-25 25V 1W 863-1N5360BRLG 1
Power and Protection Block D012 Diode 10DC1 UF4004 2 Need two UF4004 for one 10DC1
Power and Protection Block D901,D902 Diode 1N60 78-BAT41 2 Ok replacement in a PSU for 1N60
Power and Protection Block VR901,VR902 Resistor Trimpot 5K 652-3352H-1-502LF 2
Power and Protection Block SCR901 SCR 2SF656 821-MCR100-6A1G 1 Reverse the pin order
Power and Protection Block TR010,TR011 Transistor BJT 2SD223 (O, Y, G) 512-KSC5603DTU 2
Power and Protection Block TR901,TR902 Transistor BJT 2SC711 (E, F) KSC1845F 2
Power and Protection Block TR903 Transistor BJT 2SA628 (E, F) KSA1015 1
switch board c739,c740 capacitor electrolytic 3.3 uF 50V 505-MKS2B043301H00KI 2
Tone board c020,C021,C023,hanging off Capacitor Electrolytic 220 uF 50 V POWER 4
Tone board c501,c512,C730,C734,C733,C729,C727,c714,c713,c728 Capacitor Electrolytic 1 uF 50 V 505-MKS2C041001FKI00 10
Tone board C502 Capacitor Electrolytic 100 uF 25 V 647-UKL1V101MPDANATD 1
Tone board C508,c603,c604 Capacitor Electrolytic 47 uF 10 V 647-UKL1V470KPDANATD 3
Tone board C510 Capacitor Electrolytic 10 uF 50 V 647-UKL1J100MED 1
Tone board c607,c608,C705,C706 Capacitor Electrolytic 33 uF 6.3 V 647-UKL1V330KEDANATD 4
Tone board c613,c614,c721,c722 Capacitor Electrolytic 10 uF 25 V 647-UKL1V100MDDANA 4
Tone board C711,C712 Capacitor Electrolytic 33 uF 25 V 647-UKL1V330KEDANATD 2
Tone board c725,c726 Capacitor Electrolytic 47 uF 6.3 V 647-UKL1V470KPDANATD 2
Tone board D020 Diode Zener ZB1 25 0D ZR-125 25 V zener 863-1N5360BRLG 1
Tone board TR020 Transistor BJT 2SD223 hfe 44 512-KSC5603DTU 1
Tone board TR501-TR504,TR601,TR602,TR605,TR606,TR701,TR702,TR703,TR704,TR705,TR706,TR707,TR708 Transistor BJT 2SC871 hfe 417, BCE 512-KSC1845FTA 16
Tone board TR603,TR604 Transistor BJT PNP XA 495C hfe 114, 133 KSA992 2
