Sansui Solid State Amplifiers and Low Freq. Oscillation
CaseyWKC
Hey all, I have a weird issue that's come up twice now, both Sansui solid state receivers, both the same kind of issue, low frequency oscillation.
First - I have a Solid State 3500. The outputs are original - as are all pre-drivers/tx on both amp boards. Bias adjusts fine on both channels, offset is good, and audio sounds perfectly fine, but when I start turning the unit up hooked up to a load I see a violent low frequency oscillation start. Voltage swings from the outputs, in the scope at the outputs, all the way back to the main bridge rectifier.
When this oscillation starts - audio surprisingly still sounds just fine.
I have replaced all the main filter caps, tried modern subs on the amp boards, subbed new output transistors, and replaced the bridge rectifiers. This has had no effect and so the unit has sat on my work in progress shelf for the better part of a year or so (with the original components re-installed of course, as they were just fine).
This brings me to today.
I opened up a Sansui Solid State 4000 and am experiencing almost the exact same issue.
Today I found out that if bring the output adjustment down on both amp boards - the oscillation ALMOST disappears entirely (not visible through scope or on meter unless REALLY pushed) - but doing this must be just masking a larger issue.
What throws me for a loop is on this solid state 4000, the oscillation was much more pronounced on the left channel than it was the right. Because of this I swapped the amp boards to see if the issue followed and it did.
Do you suspect this issue is power supply related?
What should I look for going forward?
I should also note the original issue on the Solid State 4000 was no bias, this was fixed by replacing the tired STV-3 diodes with 3x1n1004's and bias adjusted and held steady just fine in both channels.
As always, thanks.
- Casey
The 4148’s don’t work. Also look at the emitter resistors. And because it’s on two different units look at your signal source
Do you mean the 1n1004's I used?
I have never had an issue with replacing them in the past when referencing echowars' work.
From your description, this sounds fine and is completely normal behaviour. The output stage is designed to swing voltage, and in doing so it draws current from the PSU, which can and will 'modulate' the supply rails. Winding down the bias just interferes with the functioning of the output stage so it isn't able to swing as much voltage.
Firstly, you are not using a DBT in circuit when making these measurements?
Secondly, what is the frequency of the 'low frequency oscillation'?
Thirdly, does it ever show this oscillation with no signal input?
Correct, no DBT in use anymore, no need.
I haven't taken a counter to the oscillation to see exactly what frequency it is, but I see the woofers moving in and out violently with any speakers I have hooked up - so quite low.
And no, no oscillation without signal, however; when powering up the unit the woofers do pump in and out for a second or so, but in my experience this is normal with cap coupled amps.
Thanks Hyperion!
Is your source a turntable? If so, how close is it to a speaker?
Rob
nope - not a turntable feedback issue.
Issue is with any input / source including bypassing the pre entirely and pushing audio straight into the amp.
Oscillation is increased as the low end is pushed.
Did you resolve this? I now have exactly the same problem with my Sansui 4000 on one channel - oscillation about 2 or 3 Hz. Bringing the low filter into circuit sort of stops the oscillation, but that is hardly a solution!
Just a guess, but on the schematic of a 4000 amp section, does it show an rc filter that is supposed to block low frequencies? Failing capacitor in the filter? In the first post its not clear but sounds like the original caps were left in the amp stage.
Not really, I wound up turning down the output adjustment on both channels and that helped a bit but never fully resolved the issue.
Still have the unit sitting at the shop as it doesn't feel right to list it as is.
I also had the same issue in a Sansui 4000.
Replaced and checked all electrolytics in the unit at this point.
Are you using an isolation transformer when this happens or straight mains?
Mains.
