So I finally got the Caps that rkgren1 showed me and I opened up the SP200’s. Oddly enough their SN’’s are far enough apart they have completely different Coils on the crossovers and slightly different cap values. 2 vs 2.2, 3 vs 3.3 and 24 vs 22.I agree you can save the most by using a npe cap for the woofer crossover shunt .
I am not so sure that the quality of that cap has no effect on the sound or signal seen by the woofer. Maybe less so than if it was in series but it will effect the signal seen by the woofer.
Thanks for the input, yea both these surrounds are very stiff. But are fully intact. Some kind of treated material (not rubber) with no flaking or rot evident. Just very firm with Very little deflection if push evenly on the cones lightly. The one with less bass output is just slightly more rigid. Is that enough to make a difference? The better one can move about 1mm with slight force and the worse one takes slightly more force. The better one just sounds better all around just more noticeable in the base. If no remedy I think may have to pass these on or try to find a crossover of the same vintage as to better one.Doubt if caps are the issue. The caps are not directly in the signal path for the woofer. My feeling is there's some condition issue with that woofer--maybe the surrounds stiffer or something. A config change on woofer construction in the higher number unit might have resulted in surrounds that didn't age as well. Or the bad unit may have spent more time in more traumatic conditions, like a very hot attic or something. Likewise, it may have suffered coil damage at some point.
play em for awhile and see if things loosen up a bit.
Sounds like a plan, apologies in advance to the neighbors.Yup, Sansuis get stiff surrounds throughout the years if not played regularly. Gotta pound on 'em for a while until they loosen up.
Biggles
Running them with my 2050B with Pandora on Chill House with Loudness on and Bass cranked up on low volume.Sounds like a plan, apologies in advance to the neighbors.![]()
The recap was easy but yes soldering skills come in handy.I have a pair of Sansui SP-3500 speakers I picked up about a year ago at the thrift store for 60 bucks and they sound amazing. I'm not handy with a soldering iron nor do I understand audio electronics so very reluctant to try a recap. One speaker was missing logo so order a replacement and need to replace the grill cloth. I feel that might be a job I can handle.
Another likely source of such a buzz in vintage speakers is a signal wire coming unglued where it passes through the cone. You'll have to sacrifice the dust cap to find out though.Well that didn’t take but about 20min to develop a buzz in the woofer. Pulled it out and don’t see any separation of spider and buzz only happens on heavy base notes. Seems to be from under dust cap.
I’m guessing the voice coil is rubbing. I can hold the cone steady and still get the buzz with the bass tones. Does not seem to diminish if try to push come o e way or another. Guess I’ll pop the cap and have a look. Any other suggestions? I’m a bit of a novice at speaker issues although have successfully replaced surrounds in my Marantz HD 77’s. Any direction is appreciated.
JD
Here is pic looking directly down the VC. I see a wire up top. Should I attempt to push it back around the coil? Could this be my issue?Another likely source of such a buzz in vintage speakers is a signal wire coming unglued where it passes through the cone. You'll have to sacrifice the dust cap to find out though.
