Sansui SR-929 -Erratic speed
Assil
Member
Hi everyone
I have an issue with an SR-929 which I recently acquired.
it has an erratic speed problem which occurs in both quartz lock and Manual modes. See video.
can you please recommend on this
The first thing to do is clean the speed switch with Deoxit. Open the unit and squirt Deoxit into any opening you can find in the body of the switch, then work it back and forth 30 times. If that doesn't work, get the service manual and perform the adjustments. There should be an adjustment for PLL lock, and probably for each speed. Put some Deoxit on the adjustment pots before adjusting them.
..what Dr*audio suggested..
....perhaps the motor could use some fresh lubricant...would try a few drops of 3 in 1 oil on the spindle first...if that doesnt work...maybe clean the bearings and apply some fresh grease.
....with my Denon, this worked for me...it fixed my erratic speed ...
I think you mean 3-in-1 Motor Oil...NOT their multipurpose oil...correct?
Grease in the platter or motor bearings? Or oil?
...Household 3 in 1 oil ...a few drops on the spindle's inside edge...sewing machine oil works well too.
...cleaned the bearings of the motor and added some light grease to it...the old was hardened and dirty looking...
....your newly acquired SR 929 sure is a looker Assil ..!
This stuff ;)
@spark1
I am partial to ...
Tri-flow.
It’s basically sewing machine oil with PTFE (Teflon) added.
Great for keeping road bike shifters happy too.
I wonder if graphite lubricant might be better still?
Dear All,
Thank you very much for your recommendations which I will follow
I really want to have make this turntable healthy. I have already purchased new boards and Arm for replacement
