mootej
With retirement and, in the interest of getting a nice long "winter" project, I bid a on a "broken" XR-Q9 and got outbid.
So, as a consolation prize, I bought a reasonably priced non-functioning XP-99 from the reverb site. After installing a little 3 inch belt and sanding down the dust cover with some 120 grit, all that's left is to fine-sand and polish the cover. And install the replacement stylus on the AT-3100S with a new stylus ATN-3100XE from DaCapo. Maybe get or make a head amp or a step up transformer for the MC cartridge. All things I wanted to figure out but not really the winter project I had imagined...
So then comes a non-functioning XR-Q11 for a reasonable enough price.
Service manual is a little lacking. Here's where I could use some initial help from all of you Sansui turntable lovers! Probably a lot more later and thanks in advance, but starters:
1. Missing four screws for the bottom cover - here's what I measure for a similar screw from another location that seems to work:
2.93mm thread od / 2.43mm id 1.17mm pitch, presumably type PT plastic self threading (high angle pitch to hold in plastic) most likely an M3 PT type probably 10mm long button cap phillips black.
2. Legs entirely missing - screw that works from another location are 3.92mm/2.94mm 1.43mm pitch PT type most likely M4 PT type 10mm long button cap phillips black. Listed as Sansui #51628900...
OK these two screws I think I found from China on Ebay (probably also Mcmaster although only the correct pitch in Torx, not phillips and only in SS, not black). Short story, I'm probably good there on #1 and #2.
3. What else for the legs? Service Manual lists 55122210 leg, 55221100 felt mat and 51832400 felt washer. Anybody have any pictures or measurements that might help me reproduce?
4. Three screws that hold down the motor mount from the top in the center. They look like machine screw holes. I measure the holes, id 3.51mm (probably M4?), need 8.2mm, most likely 10mm long but the pitch looks like 3 or 4 threads in 6.18mm deep hole or 1.5 to 2mm pitch. That's way off from the std 0.5 or 0.7mm for an M4. Maybe 8-32? Doubt it. Can anyone give me a hint on these?
5. Also, no cartridge holder - manual lists part no. 60, 13022300 cartridge spacer and 13010800 cartridge assembly. I get the basics but, anybody provide pictures and/or measurements so that I might reproduce in either plastic or sheet of maybe thin hobby plywood? Especially thickness...
And yet to come, cracks in the dust cover. Scratches are easy, cracks, no clue yet. Non-functioning auto cue. Saw a nice thread on that. At least the motor runs! Way cool speed sensor LED's! Who knows what else.
I still wouldn't mind dumping the CPU ROM's as well (mentioned in a previous post), but it's secondary for the moment...apparently CPU failures are not that common.
Thanks in advance, any of you that have a XR-Q9 or XR-Q11.
Till they break next time... would love to find all metal. Somebody says they are out there for one of the other turntables but they did not know which one. It's not the XP-99 which appear to be all metal. They don't fit.
