Ross6860
Only day one, but I'll leave a few first impressions. This is installed in a bedroom system.
The most recent pre-amp used in the system was an APT Holman. I have also used a Yamaha A-S301 integrated. Source is an Oppo UDP-203. Speakers are Klipsch RP-600m. Amp is an ATI 1502.
The Good - It sounds good from what I have heard so far (passive and SS). Both ends of the spectrum are extended. I was able to turn off the subwoofer. No issues with too much output at the bottom of the volume control (the APT is much louder right off the stop). Plenty of adjustment (no big jumps in the stepped attenuator/resistor ladder).
The "Bad" - Pretty sure it arrived with at least one bad tube. It sounds like sh!t, not Schiit, using the tubes. It runs hot. Really hot with tubes. Even using the SS buffer it runs very warm.
I may be sending it back due to the heat it generates. The room is too small to deal with the extra heat. Running it with an Aegir would only make things worse.
Once I get the tube issue sussed I'll give it a try with the main system. The heat won't be an issue in that space. I doubt it will displace my Parasound JC2, but you never know...
I'll report back in a few days.
