@cube-tube what is your assessment of the Freya+? Please share.
I was hoping you exchanged it as I sure would like to hear about one of these working well. My guess is the next one would be fine.
Just heard back from Schiit. They offered another unit and I'm taking them up on it.
A little gun shy, so we will see.
Nothing to loose any everything to gain!
I ended up cancelling my order for now. As much as I’m intrigued, I doubt if it would upstage my Modwright LS 36.5 DM. Although I bet it comes surprisingly close and the selectable passive could prove useful. I decided to spend the coin instead on a new miniDSP SHD to play with.
I am really liking my Saga+ that I've had for a few months, but I had to get a replacement when the first one they sent didn't work right. The stepped volume control resistors were out of order or missing, so the steps were random on the volume control. Certainly some QC issues, or they get jarred in shipping.
As nice as the passive sounds, the Schiit Sys is $50. I wonder? No remote, so not in this system.
Modwright was also on my radar. Most of the used ones a saw had no remote. A deal breaker for me.
I'm passing on their gear (sadly)
Too many reports across the internet , not just here , of their lack of QC/Reliability
Some of their products are well worth the risk. Good thing they have exceptional customer service. Never heard a complaint of them not backing up there gear?
I would like to delve into the world of Schiit ie buy a Freya but the tube section seems to cause the most headaches and being a SS guy I would like to do without....though obviously costly...after living with Bryston and Benchmark stuff you choose not to want to risk $ on things that may need repair/sent back.
Still no luck with the tube stage...
I was incorrect about any heat issues using the SS buffer. It's fine. No excess heat.
I've had mostly the SS buffer running since Friday. I'm pretty happy with it. I did listen to the passive buffer for maybe 30 minutes, and it was also very nice. Not that I've had dozens of pre-amps to compare with, but it's more quiet than any I've tried short of the Parasound JC2. The remote is all I need, volume, mute, input select, and "stage".
The attenuator relays are loud, a well-known "feature". I'll get used to it.
I find I'm deep into the volume control. Still more left to go, but this is a zero-gain unit (passive and SS buffer), so I guess I'm not surprised.
I did install a known good pair of Sylvania short "chrome top" 6SN7 in the voltage gain position. I turned the tubes on and it was quiet. I played it for maybe 5 minutes and thought I had it solved and went back to the SS buffer since I wasn't going to be in the room for several hours.
Settled in for bed and figured I would listen to the tubes for a while. Turned them back on (zero volume, full attenuation) and before I could even listen to anything I got a huge POP out of the speakers. I mean really loud. Followed by a second slightly lower-volume POP before I could hit the mute and turn the pre-amp off.
I was looking at the speaker when it POPPED and I'll say I have never seen the woofer cone move like that before. Kind if gun shy now. I may hook up some less expensive speakers and try it again. Will definitely be on the horn with Schiit on Monday. Hopefully it's just a tube issue.
So much for their fancy "Whisper-Silent Tube Stage". Like always, don't leave your tube gear unattended.
May have a keeper after all if they can get the tube issue sorted out.
More to come...
The second Freya+ is even worse than the first one.![]()
Sorry... wasn't meant to be
