thefragger
Certified Crazy.
This has been a really interesting thread. I was just wondering the logic of putting 10 ohm resistors on the cathodes. On my Deluxe Reverb I use 1 ohm resistors, so the conversion from mV to mA is direct -- no moving the decimal. A small thing I guess, but I was just wondering why not go ahead and use a 1 ohm?
Using V=IR, I think you mean a 1k resistor... ?
As far as the 10 Ohm cathode resistors yea its a pain on the 222C because they used those cathode tube socket eyelets for a few components ground tie points. You have to make a new ground point to move every single connection now on the cathodes and then insert a 10 Ohm resistor between the cathode and the new ground points for bias measuring... 10 Ohms makes it simple to set the bias. If you want 23 mA you set the cathode to read .23 VDC. To put it simply for every MA the plate draws in current the cathode draws the same MA from ground.
0.23V = 0.023A * 10R
*edit* my bad! completely misread what you meant!
It could be because the smaller the measurement gets, the less accurate the meter acts... ?
