After a long sleep, the Scott 340B powered up perfectly and is fully functional.
Per my post yesterday I stated I will compare the factory stock Scott 340B to the factory stock Fisher receivers. The list of Fisher receives includes the models 400, 500B, 500C, 800B, TA-600 & TA-800.
Frankly, the Scott 340B sounds better in factory stock than the Fisher receivers with the exception of the TA-800. The two receivers are on par and strikingly sound about the same. Same 12AX7s, same family of phase inverters, power tubes operate close to the same operating voltages, etc.
The audio transformers are different. Although audio transformer tests show most of the Scott transformers superior to the Fisher 500C, no comparisons of the Fisher receiver audio transformers exist beyond the 500C. And, the Scott 340B TR-8-5-5 were not tested either. The other Fisher audio transformers are different than the 500C. After Fisher mods the 500C is not my top pick, but is the top pick in stock form for the smoother sound. I prefer 400 or B series after mods. The Scott audio transformers are likely class A rated with regard to overshoot and ringing as shown here- http://www.one-electron.com/trans_p1.pdf and here http://www.one-electron.com/trans_p4.pdf
The Scott 340B and TA-800 have superior treble and smoother midrange in factory stock condition. The Fisher midrange is not as affected by the bass control as much as the Scott. The Scott has a slightly more pronounced bass. The Fisher overall bass is a little better defined. Both were tested with Sylvania 7591 power tubes.
Surprisingly, switching tubes in the preamp and tone control sections from 12AX7s from Radio Shack & Raytheon to RCA 12AX7 black plate is not as pronounced in the Scott. I prefer the RCA 12AX7s in both receivers.
The Scott does have a better phono section as many have mentioned in stock form. But in stock form not as good as the Fisher with the Vit Q & K40Y-9 coupling capacitor upgrade. Dave's revised phono RIAA will bring the Fisher phono sections further up in performance.
The Scott 340B FM stereo tuner sounds good and is sensitive like the Fishers. I will measure the differences later. It does not sound quite as good as the Fisher FM tuners. However, this Scott 340B tuner seems to sound better then the Scott 350D tube tuner I owned if my memory of wanting better 10 years ago applies.
The Scott 340B has provisions for setting the tube bias with a digital meter and balance controls for each section. Nice touch.
I have to say out of the box and particularly without a budget to upgrade, the Scott is the better buy in stock form. The risk without upgrading is components failure such as a shorted power supply electrolytic capacitor.
Viewing prices, the two brands can sell for the same price, but the Scott is usually a little less expensive.
So, does the comparison make my right foot tap about replacing my Fisher 400? Errr.... No. The Fisher recievers does have this 'concert hall' sound I cannot describe beyond sounding musical, exciting and powerful and I am not making excuses for the Fishers- they just have it. But, the Scott is not upgraded yet. The 340B is better overall in stock form with the TA-800 out of the picture.
