Billfort said:Got started on my second DIY amplifier – a 45 SET using a single stage 417A triode driver. I selected this circuit because I have heard it before and liked it in 45 and 2A3 versions. The 2A3 switch is pretty easy and just entails changing the cathode resistor and output transformer tap. Since I’m not sure that this amp’s <2w output will cut it full range with my 100db eff. speakers, I may end up using it in a bi-amp configuration on the Altec horns so I’ve added shunt bypassed level pots to each channel for horn attenuation. I used CAD to develop a chassis layout I liked and to arrive at a drawing I could use to produce numeric control tool punching code for a CNC turret punch press to process the steel.
My new speaker project will be 108-110dB from 300hz up so 45s should be ok in a biamp config.
Hey Nate, thanks for the compliment. Yes, just put this amp back in my system and realized again that I really ought to stop taking it out.![]()
I just love 2A3s and it's funny, when I messed with 300Bs I just couldn't leave them alone and was constantly changing something but this amp, aside from coupling cap changes, hasn't changed at all since I bypassed the level pots shortly after I built it. With 417As as drivers I don't even get to mess with tube rolling too much; WE drivers, Mullard GZ37 slow start rectifier that I just love and some RCA 2A3s to sometimes swap in for Shuguang 2A3c and I'm happy.
Yes, do have to put together a thread on my system...someday...
