i have done repairs on it myself but with help from people online telling me what to poke and prod at, with this unit i have replaced 3 transistors on the protection board, 4 by polar transistors on the power amp (one for each channel) and have adjusted the bias (that was a pain in the assI would suggest that you may want to take it to a repair shop.
Ok thanks for the help manYou can check for DC on the pot sections easily. Connect the negative lead of the multimeter to the chassis, and set the meter for the lowest DC mode. probe each of the leads of the volume pot , and see if you see any DC voltage (there should be none). You should turn the volume up some, so the wiper is not at the ground end of the element when checking. There will be 4 terminals for each section (low end, wiper, high end, and loudness tap)
I know i already replaced the 4 2sc1451 on the power amp board as i had read that those 4 could go out and take the whole system with them, so i know i put in new ones, but i hadn't heard about the other two, looking at the schematics ( its all a puzzle to me lol) i can only find the 2sa726 transistors, cant seem to find the 2sa725? what would i replace the 2sa726 with?2sa725,2sa726 transistors are notorious for getting noisy. I describe it as "Rice Krispies in Milk" Snap, Crackle, pop. And the 2sc1451 also. These 3 are on the AK "TOP TEN MOST WANTED LIST" Replace on site. The Amplifier board itself has 8 2sa726 and 4 2sc1451's. Do a pre-emptive strike and get rid of them before you REALLY have problems.
Hey sorry man just didnt know if you had seen my last reply, would replacing the 2sa726 with ksa992 be right? and if so would these be the right ones? https://www.mouser.ca/Search/Refine?Keyword=ksa992 and does it matter which ones i pick from that list? as in are these just all the same ones but sold by different people?2sa725,2sa726 transistors are notorious for getting noisy. I describe it as "Rice Krispies in Milk" Snap, Crackle, pop. And the 2sc1451 also. These 3 are on the AK "TOP TEN MOST WANTED LIST" Replace on site. The Amplifier board itself has 8 2sa726 and 4 2sc1451's. Do a pre-emptive strike and get rid of them before you REALLY have problems.
You can check for DC on the pot sections easily. Connect the negative lead of the multimeter to the chassis, and set the meter for the lowest DC mode. probe each of the leads of the volume pot , and see if you see any DC voltage (there should be no more than a few milivolts, or none). You should turn the volume up some, so the wiper is not at the ground end of the element when checking. There will be 4 terminals for each section (low end, wiper, high end, and loudness tap)
Well from what you describe, it sounds exactly like what your saying,when i was reading the high post it would go up as i turn the volume up which would indicate as you said to be the caps on the tone control boards,it would be the cheapest and probably the easiest parts to replace on any of the boards as i can pull them out and have lots of room to work with on them,unlike the other boards in side lol its going to be about a month before i can order the replacement caps and open back up, so i will let you know once i have them ordered, would you happen to have a link to these caps? and well im on those boards should i replace the transistors on them as well? and if so with what?I am assuming the measurements you are showing are in volts, If that is true then you surely have some capacitors leaking DC on to the pot. I think the first thing I would do is replace C1 and C2 (1uf 25v) on both AWG-024 Control Amp PC boards. It sounds like there is some leakage through those capacitors back into the volume wiper, although it is hard for me to tell which elements of the pot you were describing in each measurement The center terminal is the wiper, and the black wire is the loudness tap (works with the loudness button). You can determine which of the two terminals is the high side of the pot by observing how the wiper goes from the low end (which is grounded) to the high side, as the volume is turned up. If you look at the foils on the PC board, all 4 of the low side terminals should be connected to one foil.That side will always measure very close to 0 volts as it is grounded. If you have leaky capacitors on the wiper, WITH THE VOLUME TURNED ALL THE WAY DOWN, the wipers would also measure very close to 0 volts as the wipers are effectively connected to the low side.with the volume all the way down. First look for any voltage on the high side of the pots (opposite the grounded side). If any is there the issue is likely in a previous stage(before the volume control). If there is no voltage on the high sides then turn the volume up some (25-50%) and measure the wipers again. If there is now voltage on the wipers then the downstream C1 and C2 on the control amp boards are likely leaky.
Ya i also just realizes the price on those parts with shipping would be close to 50 bucks, so maybe just replacing the caps you mentioned would be a good ideaI am not one to just start replacing parts without a good reason. I would certianly replace all the 1uf 25v caps on the board, and would measure the voltages on the others with a multimeter, and see if any others are showing signs of leakage (voltage on the lead that should not have any). Those 1uf electrolytic capacitors could be replaced with film capacitors if you like.
Hey man im about to order the caps you suggested to replace and wanted to know if you could take a look at what i have picked as the replacement and tell me if its ok?I am not one to just start replacing parts without a good reason. I would certianly replace all the 1uf 25v caps on the board, and would measure the voltages on the others with a multimeter, and see if any others are showing signs of leakage (voltage on the lead that should not have any). Those 1uf electrolytic capacitors could be replaced with film capacitors if you like.
