Doug Weiss
Member
Hello all, I have been gathering parts for a simple stereo SE45 amp per the JE Labs schematics shown. Was wondering if I use a PT with a CT 5 volt winding, could I use each side of the tap to power each of the 45 filaments? Will there be any unwanted interactions, since the 45s would share one leg of the filament supply. I could also run both off the same half of the 5v supply, as it is a 3A tap. I was planning to use a 6AX5 rectifier, and one of my PT options has plenty of amperage on the 6.3v tap to run the preamp tubes and the rectifier tube. I'll be running old Triad HSM-79 outputs, and the PT will require a little tweaking to get the voltage right, but that's easy enough. The goal is to minimize extra iron on the chassis where possible, and that's where I'd like to use that 5v CT option on the PT. Thanks!
