setup1
There are a couple of JE Labs versions. This one shares the filament trafo. No doubt the isolation is better with separates, but I could also do dual monos on the same chassis if it matters.
This schematic was a reverse engineered version of the original Simple 45 amp below. This was the very first SE amp I built using whatever parts I had in my bin. The OPT actually came from a trashed HK 500 integrated - PP, no air-gap. This was the mid 90s.
All subsequent versions of the Simple 45/2A3 were based on the schematic below.
As many have stated above, it's best to use separate filament transformers in SE configuration.
