SE to PP linestage
PakProtector
AK member
I want to try another PP output linestage. I have one that runs a LTP of EL84 and don't quite feel like duplicating it. Sooooo....
12B4 SE amplifier, LED biased and resistive loaded, followed by another 12B4. Maybe followed by a 12A4...
B+ around 400V, 15000 Ohm plate load on the main amplifier, and 10kOhm plate and cathode loads. Plate voltage on the amplifier stage about 120V. Big coupling caps( motor runs, 370 VAC/5 uF most likely.
Thanks to REALLY poor PSRR, the B+ is going to need some competent filtering.
It ought to be fun... :) It will need to drive a digital cross over.
Douglas
Douglas
Why not use a 12AU7 or 6SN7? Back in the late 1950s, Ampex made the 351 tape electronics (on which most of the RCA Living Stereo catalog was recorded). Those electronics had a push pull output using a 12AU7. They had no problem putting out +24dBm. 0dBm is 1 mW into 600 Ohms BTW, which is plenty of Voltage to drive most amps.
The output transformer for a 12AU7 or similar tube (6SN7, 6CG7) would be a lot easier to build than one for a power tube- you'd get wider bandwidth and lower distortion.
If you used a 12AT7 as the output tube, driving a PP output transformer, using a Constant Current Source in the cathode circuit you'd have enough gain that you might not need another tube in the line stage and it would be able to handle a single-ended or balanced input. I used exactly this sort of circuit in a microphone preamp I recently built. It makes +24dBM at clipping, about 32V. Output transformers for this application would be easy to find.
interesting. have a pair of ampex 351 modded as standalone mic preamp. i have not looked at the circuit.
Douglas
Also, have you ever explored the possibility of a bipolar supply?
I'm assuming you want to go unbalanced to balanced signal. How about a DC coupled common cathode to cathodyne?
B+ around 400V on a 12B4? I would make sure to reference the heater 50% of B+ since those do have a 200V cathode to heater limit.
Most low PSRR issues can be resolved.It just take time with signal analysis to find out what method of noise cancellation works. So you don't necessarily need to build a virtual battery to make a low noise circuit.
This circuit would need coupling caps to be used with a transformer. In a balanced circuit, having equal impedance to ground is an important aspect in order to maintain a high CMRR to prevent noise. While the B+ is going to have a low impedance to ground, it will not be the same thing as ground; the impedance to ground will not be the same from pin 2 to pin 3. As long as the power supply is low noise this might not be a problem, but if the interconnect cable were to pass by a hum field (power transformer or power cord) it might.
An output transformer bypasses this problem entirely as its impedance to ground is nearly infinite.
That's a lot of hardware for a pair of mic preamps! About 30 years ago I had a bunch of output transformers made that were copies of the Ampex output transformer used in the 351. The headphone/feedback winding was omitted. I used those transformers in a 6 channel mic preamp I built up.
Edcor makes a part that would be suitable in this application.
Using that part, if we are only talking about a line stage, you'd only have a volume control (2 deck) and two stopping resistors besides the parts used in the CCS if a 12AT7 were used to drive that transformer using the transformer as a plate load for both sections. That's a pretty simple circuit!
man, thats really cool
ampex 351 channel modded for standalone mic pre attached
heres albinis page on it
the B-17331 input transforers are popular MC SUTs.
I think you are just reading into it too much for the simple diagram it is. But on a side note, I have made dc coupled innerstages too. The OP was excited to use their motor run capacitors as coupling capacitors anyways and I would assume that they know how to make that part of the circuit. Much less anything needed to be added to trim signal symmetry.
But what the OP will learn is its not really possible unless they run a differential amp and used matched triodes. Especially when it will need to null properly.
Douglas
i am eager to see what you come up with
Douglas has experience with some rather out of the box circuit designs, so I'm confident he has a plan to make it function.
I'm sure he can get something functional, Even though the tube selection is a little esoteric. Since it only needs to provide ~6 V with an output impedance of 10Kohms max (+18 dbu ) 12B4 followed by a pair of tubes in differential cathode follower as a buffer should work just fine. Even though a differential phase splitter with differential cathode follower would be an easier circuit to build up. But he didn't want to use a long tail phase splitter which is the common name for a differential phase splitter. I think what turned him off on the LTP was you can't use a simple LED CSS and you would have to use a high voltage NPN transistor for the CSS with a voltage divider base bias from B+ and stabilized with a zener diode. Of course this would be a better circuit as you could use a moderate size capacitor and inject the power supply noise from B+ into the CSS to invert it at the cathodes and cancel the power supply noise in the circuit.
I have a tool box with Albini's signature on it, from when he came to the Twin Cities to do a show. He put the LOMO logo on it too. By accident someone in the band left the purse that had all the payments from the shows they had done on that tour. They were pretty glad to get that back!
WRT the input of the schematic at the link: the B-17331s are the Ampex input transformers. You might want to run a square wave through them and look at the output. I used a pair of those in a mic preamp I designed just last week; there was a bit of overshoot on the square wave and the transformer began rolling off at 12KHz. To solve that, I had to load the output of the transformer (since I did not provide any input loading); that value was 60K which killed most of the overshoot and flattened out the bandwidth so it went well past 20KHz.
The consideration is that when driving balanced lines usually ground is ignored. There are a couple of reasons for this.
The first has to do with Common Mode Rejection Ratio (CMRR) and is the reason input and output transformers do not use a center tap. The center tap degrades the CMRR quite a lot. The second reason is by ignoring ground, ground loop buzz cannot be amplified. When you have two outputs, as in the case of a differential amplifier driving the outputs directly or via CF circuits, you have both problems, as the outputs are not exactly the same; tiny differences can result in fairly big changes in the CMRR, plus of course ground is involved so the shield of the interconnect cable, which is normally just a shield, is now part of the audio circuit and thus influences the 'sound' of the cable.
There is a standard for balanced operation known as AES48. It outlines the practices used for proper transmission and in particular how the circuit is to be grounded. Typically a balanced line connection is also low impedance; in the old days the termination standard for line level was 600 Ohms. If you look on the back of the Ampex 351 tape electronics, you'll find a switch that puts 600 Ohms across the output. Its there because the output transformer needs that load to have flat frequency response in case the electronics are not connected to a line level input (such as a mixer console). This would allow the electronics to drive a high impedance input with proper bandwidth.
It is on this account that balanced equipment output levels are specified in dBm rather than Voltage. 0dBm is 1 milliwatt into 600 Ohms; a VU meter looking at that will read 0VU. The output of the Ampex 351 is good to about +24dBm so its got plenty of output to drive any input with lots of headroom.
The circuit I proposed in my prior post has this capability plus it supports AES48. You don't have to worry about matching triodes or the like since the output is the secondary winding of the transformer. Any 12AT7 with reasonably close internal triodes (but not matched) will work fine- the only difference will be how much distortion is made, not whether the output is properly balanced.
The only issue with supporting AES48 is connecting to single-ended inputs. In some cases you can get a buzz if you don't hook it up right. That is why Rane put up this page years ago. If the circuit isn't compliant, you don't have that problem because the non-compliant circuit is already referencing ground in the generation of either the pin 2 or pin 3 signal. If you use an output transformer though its no worries tying one side to ground; transformers are very good about converting from single-ended to balanced or vice versa.
Its an outdated standard and only applies with transformer coupled equipment (for now)
10K ohm balanced has been the new standard for the past 30 years on transformer-less balanced line on PA equipment.
In the case with the Ampex 351 tape machine, which was made in the classic AES48 standard, it has the 600 ohm resistor so it would have that load for its VU meter. Without it, the transformer-less console would load it at 2.5K which is the other modern impedance convention for balanced microphone line and the signal level would be almost 4 times higher burying the VU meter past +3.
I've been using these transformer modules lately to either input or output balanced connections on my tube gear and they work great + is simple to install.
its a simple way to get an unbalanced line circuit to interface with balanced, however its not the wanted use case here.
I have already got a TX coupled LTP linestage( I like it ). The active element is 6S4p-EV. Currently in place is the EL84(triode rigged ) LTP one. A 12B4 SE directly tied to a 12B4 split-load is what I meant to say originally( as pictured by @sddave ). At the currents I intend to run, plate resistance should be quite close to the data sheet mentioned value.
Douglas
The standard isn't out of date. Its was amended quite recently. It does not apply to only transformer coupled equipment. You can use three different methods of driving a balanced line while supporting AES48; transformers are one way. You can also do it with a solid state circuit that is transformerless. That Electronics makes a chip for that. There is a third method my company patented.
10K is not typical of studio equipment. 1K is more common and I still see 600 Ohms (which is common due to legacy equipment). If you look at the transformer at the link I provided previously, you'll see its designed to drive 600 Ohms. Jensen is a well known supplier of line level transformers who also is still making them for 600 Ohms.
The 600 Ohm resistor which was switchable in the Ampex 351 was, as I previously mentioned, used to load the output transformer. This in turn allowed the VU meter to read correctly. If the transformer was not loaded, it would not have flat frequency response due to inter-winding capacitance. It would also not provide a proper load for the output tube. So the resistor was available in case the unit was to be used with an input of high impedance. The fact that it also corrects the VU meter reading is thus indirectly related.
10K +22dbu is a standard that started to be made about a decade ago called the electrically balanced which is a product of the resistive load of the line driver without a connection. There is another convention that is 50K -22dbu that is used in balanced line input for active studio monitors. 1K-2.5K was another capacitor or DC coupled convention besides the old DC coupled convention of 250 ohms that still in the broadcast sector. Jensen has a lot of different transformers but in reality a transformer doesn't really have a set impedance per say, but might have been tested to work in a variety of ranges. To give you an example, the DIN rail mount adapter Jensen DIN-2LI is a 1:1 but its full bandwidth bandwidth impedance is 14K and anything loaded lower in impedance does not change the bandwidth. However, its not used in reflected impedance circuit and just signal coupling, So source impedance is determined by the primary termination and output impedance is the resistance product of the AC signal current and voltage induced across the secondary as its resistance in parallel to its loading resistance in the secondary. So if you look you will see test circuits with a signal generator with a source impedance terminating the primary either in balance or unbalanced convention, as well as the minimum resistive loading of a 14K secondary with a 10K resistor which results in a 3.2K output impedance line established.
In reality there are several impedance line conventions used from 50 ohms to 250K in audio and 600 ohms is just one of the conventions used still today. But 600 ohms is not the only 1:1 transformer used.
As far as balanced line drivers you don't necessarily want to drive it into a 600 ohm load, as it might have better signal characteristics with a higher impedance load. That is why you should characterize it across different impedance. As not all things are 600 ohms. I would be impressed if that balanced line IC could drive into a 50 ohm load and keep reasonable signal characteristics across all impedance conventions to 250K. As there is limiting constraints due to current fold back and voltage cutoff with semiconductors.
If I can have the Split Load section developing its rated gm, output Z for the two phases will be OTO 160 Ohm. A bit higher if I don't get the current high enough. Loading it asymmetrically is not going to happen unless the input stage of the amp following clips and grid current flows. I would call that very unlikely... :)
Douglas
Since 600 Ohms is a legacy value it is still in common use. If a higher impedance is to be driven, the transformer must be loaded properly to prevent ringing. If that input impedance is over 6000 Ohms the simple solution is to just put a 600 Ohm resistor across the output of the transformer. Since this is a line application 600 Ohms is the usual value rather than something lower (my Neumann U67s are set up to drive either 50 or 150 Ohms for example).
I think the That Corp 1606 might drive a 50 Ohm line just fine as its output impedance is 4 or 5 Ohms.
We're on a side topic, but for driving a balanced line with tubes there's really only two ways to do it. You either use a transformer or you use a Circlotron with a DC feedback servo (which the technique used in my preamp). Both float WRT to ground and both generate the pin 2 signal WRT pin 3 and vice versa.
The issue is that in a balanced system the signal driving the amp isn't supposed to reference ground. This is done to avoid ground loops. A secondary advantage is the circuit is more immune to interconnect cable colorations. If you have ever auditioned two cables side by side and heard a difference, that's what I'm talking about. By use a low impedance output and driving a low impedance at the input of the amp (hence the use of dBm as an output spec in balanced line equipment) interconnect cable noise, colorations and other issues are swamped. This means the cable will be neutral and also allows for long cable runs without degradation.
