I will start this off by saying although I've dug through many threads about restoring, recapping, refoaming, repotting these speakers I am pretty much a total newbie to actually doing the things.
The other day I came across some pretty decent looking AR-5s on the local marketplace. Took em home, took off the grills, and the foam is gone. Alright, I can handle that.
Pull the woofers. One measures 6 ohm, which is fine I think, and the other, open. Not great! So I dig out the rockwool and look at the crossovers:
One appears to be fine, the other looks like where the resistor wire (?) is on the little board has basically burnt to a crisp including a bit of the surrounding insulation.
I didn't remember to make not of which speaker came out of which cabinet but am I right to guess that the blown woofer probably came out of the cabinet with the fried resistor?
My questions are:
1. What might have happened here and what kind of damage may this have caused to the blown woofer, if in fact it came out of the same cabinet? Or are these things unrelated?
2. What might it cost to get this blown woofer fixed? I'm looking around and guessing I won't be able to find the right drop in part any time soon. I'm not far from Millersound, I'm guessing that is the best place to go for a repair.
Thoughts? Next move is going to be clean up the pots (or bypass) to see if the mids and tweets are functional. Thanks for any help
My questions are:
