I just went through one of my Pioneer CT-F1000s and I'm having a rewind issue that was very much unexpected.
It has all-new rubber and a new (donated from an FG-driven motor Technics) low-hours motor. It has GREAT torque in both directions and will rewind a tape to about 80% and the rewind TIME will be ahead of spec by a comfortable margin. And then...it slows down (instead of speeding up like one usually sees) and slowly comes to a stop. I suspect it's mechanical and NOT electronic as I can take the tape out and the rewind hub still has a LOT of torque. It does it on multiple tapes. I checked it when I first changed all the belts and WJOE-manufactured rubber replacement pieces and it worked (I thought it did anyway) perfectly. I had to travel for a couple of weeks and when I returned it started to exhibit this weird behavior with an approximately 90-minute tape (The Elton John Australia tape) and now does it with a number of tapes. Any helpful insights are appreciated. I've worked on a bunch of these CT-F's and I've never encountered this problem before including on other CT-F1000's. It's a low-hours sample (I've had it for about twelve years and it worked fine until the playback function stopped working owing to idler/motor pulley interactions, as described before now fixed) and I did NOT note any cracks in anything ANYWHERE. It's a pickle. TIA...
