Pio1980
AK Member
The NTC is a good idea when a ramping is needed.
I did that with two CL-90 in my Dyna Stereo 70 at the fuse holder.One benefit of installing a thermistor in a 50/60 year old tube amp is that even after its warmed up, it still provides a drop in line voltage of a couple/three volts.
My line voltage is normally 120+/- 1V. This keeps me close to the design center of 117V that most of this equipment was designed around. The higher B+ can be stressing the ancient insulation inside transformers and aging capacitor dielectrics if the thermistor is bypassed after it's warmed up.
I've seen where some folks are putting two thermistors in series to cope with higher line voltages.
