mashaffer
OK, so here is the plan. I will build a quick passive volume control and make sure it works with the amp as currently constructed. That will also give me an idea of the volume levels I can get as a starting point. Then I will rewire the heater for the 12AY7 and change the resistor values as above as a starting point and compare the results. At that point it is just a matter of optimizing R values (easier said than done).
As to the speakers, since I will be using an L-Pad for tone control I think that I will put the crossover in the main cabinet rather than each individual speaker. Then I plan to use 4 wire Speakon connectors for solid connection but still put a 250 ohm or so resistor across the OPT secondaries just in case it is run sans speakers buy a careless youth.
I can have a separate set of binding posts for subwoofer connection and or alternative speakers.
I will report back when I get the volume control done.
mike
mike
