Need sony 75es dat machine rotery encoder? Anyone know where to get one?
also called a mode switch......http://www.partstore.com/Part/Sony/Sony/DTC75ES/Sony/Sony/146472432/New.aspx
Out of stock on the sony site/hard to get part........does anyone know of a used parts dealer? I tried ebay to....cant find it......thats all it needs to work.
This seems like a very commen prob with this machine/and if you can fix it your self and find the part/there not to bad.?
Would appreciate any info guys....
Thanks,
Ed
If the rotary wheel is broken and you can still find the 2 parts you can fix it using power glue. The following problem then is to get the wheel back on the pin of the encoder itself. You need some pressure for it and the wheel will brake again. Therefore, a very thin mini-piece of plastic (maybe cut from a plastic folder) can help glued directly on one side in the middle of the wheel giving it more strength. It works fine since the wheel is just driven and doesn't drive anything itself except the encoder (sensor) needing less power.
I did it on 2 DTC-700. The original wheel is a misconstruction, thus a malfunction is implemented after a while: There are 2 tiny holes in the wheel in addition to the main hole for the axis of the encoder, probably to make it elastic enough to be pressed on this axis. However, the remaining material at this location is substantially not enough. The always existing static force will damage this wheel especially after aging. It even can break doing nothing with the unit or just being shipped to an other place. It is always a nice surprise sending out a well functioning and tested unit and getting back a reclamation from the receiver immediately, isn't it ? - Now you know just one possible reason ....
