Willeecue
As I said I upgraded from a much simpler and smaller system.
Im not an audio engineer so my best answer as to what I am trying to achieve is that I want the sound to be as good as it can be.
"What is good" you are going to ask ... I dont know ... that is why I came here for some advice.
I have learned that the room will effect the sound from the speakers a lot.
When I bought this setup it was on a table out in the open of a large area and it sounded fantastic.
Bright, clear, with good bass.
But at home in my living room it sounds mushy and not as bright and clear.
I tried setting it flat using the sound meter and a test tone cd but that made it sound terrible.
Lack of knowledge of how to measure and adjust could account for that.
This equalizer / pre-amp does have a switch that bypasses the equalizer part.
So I can switch it in and out to hear the difference.
As it is set (smiley face) there is a small boost on the low end and just a touch of brightness to vocals.
Being 74 years old and a competition shooter in the 70's there are higher frequency's I wont hear no matter how much boost I use.
So far the difference simply does not justify the cost of the equalizer.
I am starting to think a nice straight up pre-amp with inputs for phono, CD, and tuner would suffice.
Another thing that puzzles me is that if the led lights on the amp are accurate then less than 15 watts per channel is adequate.
The amp is capable of 150 watts per channel so I feel like I wasted a lot of money if 15 watts is all I need.
Wish the Amp had A/B speaker outputs so I could compare speaker sets
Perhaps an outboard switch later on would do that for me.
Is being an audiophile like chasing the holy grail ... always seeking something better that you suspect exists?
Never completely sure you are satisfied with what you have.
Always looking at expensive equipment thinking it would sound better?
