gregmcm
I'm getting back to some work on my Setton RS660. The issue I'm dealing with is the power switch and speaker thump when I turn the unit on. Have done some reading and these switches are known to be problematic and were also used in some Lafayette units with similar problems.
I've managed a work around by connecting the speakers to the "B" speaker terminals and when I turn the unit on I wait for the speaker relay to engage and then move the selector switch to "B" and no issue with speaker thump when I do this.
If possible I'd like to have the switch work as intended so before I dig in I wanted to know:
- are the two capacitors attached to the switch (see photo which shows one of these and the other is located on the other side of the switch) a particular type of capacitor. I've never seen one like this before. They're marked .047uf 250V
- if these capacitors are out of spec could they be the cause of the speaker thump? I tested both and they read .061uf.
- would a .047uf 250V Film Capacitor be a suitable replacement.
I would note that there are no other issues with the switch - flickering etc.. I'm going to pull the switch and have a look inside as no doubt it could use at minimum a cleaning.
Thanks
Thanks
