Hi, a total newbie here. I hope you are all well. I have a MC225 which I bought about 25+ years ago. I hadn't used it much in the past. Like many people, I started listening more during the pandemic. Everything was fine until a year ago. One day, all of sudden, the sound got very distorted from both speakers. The setups I have are usually either Speakers-MC225-DAC(Shiit Modi)-Streamer(Raspberry Pi) or Speakers-MC225-CDPlayer. I have never used a preamp and I always use the gain nobs on MC225 for volume control. I hardly increase the gain over like 25%.
I have uploaded the sound I recorded while playing three songs (a little each).
I have another amp so I tested the speakers, DAC, streamer, and CD player. All sound fine with the other amp. I also tried to test the tubes on MC225 using a method I found in YouTube. I don't have any tube testers. I just used a multimeter. So I am not 100% sure, but the tubes seem to be okay although I am not 100% sure. I don't know how new the tubes were when I bought this amp 25+ years ago but since then I never replaced any of them. So although they were not used much, they are still very aged I believe.
I am not sure if this caused the issue or is even related or very much coincidently but I think the problem started happening right after I switched around the connections between 4 ohm and 8 ohm on MC225 with the speakers.
Can someone please let me know what potentially could cause this issue? Has anyone experienced the similar problem? If so what was the reason? Could it be due to bad or aging tubes? Or something inside the amp went bad or got broken?
Any help or guidance will be really appreciated. Thank you for reading my post.
