hertzdonut
Press Play and Stand Back
(Preface: I've fully recapped two SX-850's and a PL-630; so it's not my very first prom.
My SG-9500 worked great previously. My choice to recap was simply for longevity's sake. I hit all switches with DeOxit first, and then went on to recapping once my parts arrived.
I started on the power board for this SG-9500, and have replaced 11 'lytic caps. Being a believer in "check-as-you-go-along", I plugged the unit in and flipped the power switch. No light. Hm, not what I was expecting. (fyi, there was NO noise or smoke or anything. Just...no power)
Going back to the beginning, I rechecked the values on the caps, comparing old, removed caps to the new. I then verified that each new cap was properly oriented. (When I was progressing on the install, I pulled each cap, one at a time, and compared the board to the schematic. All matched up: values, polarity, etc. The only difference was my "B" version board sported two additional caps)
Next, I double-checked my solder work joint by joint. No cold joints, no bridging, no spatter. Then, plugging the unit in, and flipping the power switch on, I carefully wiggled each cap, checking to see if the light came on or even flickered. Nothing.
I shut everything off, and decided to check the fuses. Pulled, checked, all 4 are good.
Lastly, I went to the schematic to find where to take some readings. I'll be the first to admit I don't know crap about schematics (other than identifying parts) but I saw where there should be some voltages on some pins. I grabbed my DMM, and took readings. And those were good too. (I’ve uploaded the schematic and highlighted the three areas [five pins] that should have voltage.) (I’m also uploading the foil side image, too, if that helps)
Sooo, before I tear all the caps back out, is there somewhere else I should be looking? If I’m getting proper readings at the pins, doesn’t that mean the board is performing properly?
Oh, one last thing: Thinking that maybe just the bulb itself (the power indicator lamp) was blown out, I hooked the unit back into my gear, but nope, there is no power.
Thanks for any help shared!
Jeff
Jeff
