Hi all,
Today I was listening to my Sherwood S-5500ii when all the sudden I heard a hum from the right speaker. Before I could get over to it to shut it down, the main fuse blew. I went ahead and tested the output tubes, and found one of them had shorted. I opened up the amp to check and see if anything obvious had failed internally, but everything seemed fine. I'll be completely honest here - I was running this amp completely original. All the caps and other components had been tested though, and were good. I went ahead and tested caps again - coupling caps showed no leakage at working voltage and electrolytics all tested good. I went ahead and changed out several though while I was in there, figuring it was easy enough and these parts are very old.
After not finding anything wrong, I put in a new 7868 and fired it up, watching the tubes and current draw of the amp. Amp seemed to be drawing a bit too much current - around 1.5a, but all output tubes looked happy - no red plating. Then all the sudden I heard the hum and shut it off, but not before the tube I had just put in shorted.
I am at a loss as to what could be wrong here. I have tested just about every component, and it seems like such a simple little amp. Does anyone have any idea what the issue could be?
