More
Novar socket info, options and a question.
I have several Sherwood things that use 7868's and my Dyna-Jet 707 tube tester's novar socket is loose with normal 7868 tubes. and too tight for fat pin tubes. I won't get to work on them until the snow flies but just in case, I've been seeking affordable replacement sockets.
I have found a
NOS Zenith 873-53 kit on the auction site which contains a brown molded plastic novar socket with holes on 1 5/16" centers. It is screwed to a metal adapter plate with oblong holes on 1 3/4" centers. I've seen a few of these - some were affordable.
Here's a picture of the kit:
The socket is the same brand as on the Dyna-Jet tube tester. However Pin 8 is blank - no connection, so it will work for a 7868 tube which has no connection on pin 8, but not for a 6JE6 tube if the G3 connection is needed on pin 8. My Sylvania tubes fit nicely in it.
Otherwise, there is a seller on the bay listing a "9 pin red GLASKYD Novar tube socket B9E fit 7868 6JE6" - says made in USA 1963. I hope I don't need 12 of these.
Anyone know of any successful methods of thinning out the pins on a fat pinned tube, so they'll fit the Novar sockets? (Dip the pins in acid until they fit in the sockets?????)
