Good to know. ThanksFYI, when questions about pricing are asked, you run the risk of the thread being kicked to the Dollars and Sense forum. It's in the rules, take a look.
And WELCOME to AK, jvanroo!
Shoot, I'm just seeing this now--I'm on here sporadically--I just bought another S7100A on that auction site for $120. To me it was totally worth it as I know this receiver well and what it's capable of. Also the case was in great shape and the potentially bad OFF/ON/VOLUME knob was fine. You will hear many people balk at paying $100 or more for old receivers; I'm not one of them and I don't wait for the best deals. If I want it, I buy it (within reason). Did you get it?I have a question in response to your comment.
There is an s-7100a for sale in my area for $125. The posting says it works great. I definitely like the look of it and if it sounds as good as you say it does, I may want to add it to my system.
Is this a good price, or should I try and talk him down?
After getting advice from the previous post, I offered $75 for it and the seller ghosted me.Shoot, I'm just seeing this now--I'm on here sporadically--I just bought another S7100A on that auction site for $120. To me it was totally worth it as I know this receiver well and what it's capable of. Also the case was in great shape and the potentially bad OFF/ON/VOLUME knob was fine. You will hear many people balk at paying $100 or more for old receivers; I'm not one of them and I don't wait for the best deals. If I want it, I buy it (within reason). Did you get it?
You can often up the capacitance of the filter caps 50% and get close in size and since higher voltage is okay, with some receivers similar sized caps can get rather expensive. You don't want a cap too low in voltage rating or it can blow.
On my S-7200 I used strips cut out of foam sheet, can be found in one of the back aisles of my Local Hobby for less than $1. Stuff comes in handy. Helps take up the gap and hold them tight. Replacements were close but not quite enough.
After replacing the electrolytics and a number of transistors with noise issues now my S-7200 is a sweet sounding unit. As-is auction unit when received had DC on one channel about 200 mV and all sorts of odd noises in the background of one channel - after some time playing that way the differential pair on the channel with high DC started to rat-a-tat-tat after about 10 minutes after turning it on. Took some time and sleuthing to get all of its issues ironed out. It paid off. Now you can have it on aux with no source turn it all the way up and its hard to hear anything. Power switch still works.
Have read a lot of good reviews about their low end S-7100 and S-7100A units along with the higher end S-7900A/8900A (believe 8900A is FM only, 7900A is AM/FM). The S-7200 gets talked about a lot relative to the number that come up on the auction sites.
The old Sherwoods are sleepers, get overlooked in the market so prices can be low but when you hear one they are great units. The British site select45rpm.com reviews a bunch of vintage units and had been harsh on the S-7200. I guess last year they finally restored theirs because late last year the very negative review got replaced by a very positive one.
View attachment 1395609View attachment 1395631
Those are not bad numbers for direct coupled DC offset with no adjustment trimmer. Got spoiled with the cap coupled models or ones with DC adjustment. Those numbers are good. If you read the service manual on the S-7200, the official Sherwood view (and of many other manufacturers) a DC offset of more than 200 mV you need to find the offending component. Below 200 mV considered okay. My impression close to zero is ideal, below 100 mV is good, as you work toward 200 mV eyebrows should rise, over 200 mV time to find the problem. Basically on the direct coupled designs if I measure DC offset in the tens of mV its good.The amusing part of all this is I thought it was a cap-coupled receiver and was dismayed to see -20mV and -60mV at the speaker terminals.
With the direct coupled speaker protection fuses and using lower power speakers often will put a 2 amp fuse in.If you think the woofer will get toasted before the fuse blows, why don't we put in lower value fuses ---say 1.5A instead of 3A?---to protect our cherished speakers? The 7200 has enough power that I can see myself turning it up!
Nasty DC offset is when an output has shorted and is putting power supply DC voltage to the speaker. If no protection relay system which goes first, the fuse or the woofer?
I noticed with my S-7200 before the power switch broke that the base noise with FM had been getting louder. Does not seem to be there with other sources. When I fix the power switch I need to find the offender, probably a noisy transistor. Hopefully it is one at the back end of the tuner circuit.
If there is broadband background noise in the S-7200, does it respond to the volume control? If so would go after the 2SC693F on the tone board. If not likely in amp boards. Watch it, all those wires you need to move out of the way to get the tone board out they used some fine stranded wire and I had to keep finding one or two that broke, usually at potentiometer or selector tabs, every time I worked on that board. Try to keep the stress on those wires to a minimum. Would work on that board and be greeted by a dead channel. Not always easy to see which one broke loose. Sometimes had to keep looking before my eyes finally locked on the missing wire.
dly66, say you and I wanted to lower the DC offset on our 7200s---would this entail replacing transistors in the driver board? I've recapped everything except the FM/AM boards and I did replace the transistors on the tone board per your suggestion.
Missed that question before so a delay in answering. Working on a few loose ends then should tackle the formerly mouse infested Pioneer SX-9000 next since I am sitting on the caps and transistors. Good bit of money tied up there - my electrolytic/film cap list for it had 87 as the total count for it. Probably after that will finish the Sony STR-7065 since I have already done a good bit on the amp and power supply sections, then it should be time for the CR-800. Might get to it during the winter. Most work during the winter when the days are short and cold weather you spend more time indoors. With Covid-19 even less likely to spend time elsewhere this winter.Have you gotten into the Yamaha CR-800 yet? It's a fine machine and a full recap (do the toneboard) will dramatically improve the sound.
