kendo581
Hi All,
I'm new to the audio realm, and have been slowly putting my setup together. A while back I purchased a Sherwood s7210A because I heard it has great AM/FM reception (I listen to a lot of radio...) and recently purchased a pair of ADS L520 speakers (found a good deal, they sound great). I found specs on the Sherwood on another AK post that said it is was "RMS Power: 26 watts x 2 @ 8 ohms, 20 - 20,000Hz":
http://www.audiokarma.org/forums/showthread.php?t=34208
On the back of the ADS L520 speakers, it says both "50watt nominal 6 ohm nominal" and "100 watt nominal 4 ohm nominal".
Is this an OK setup to run? Is there anything I should be careful about? Should I not be running this setup at all?
Thanks for helping out!!!
