I was able to unscrew the larger weight from the inner sleeve. When i go to attach the inner sleeve to the arm and tighten the screw, how do i get access to the screw from the bottom. Am i supposed to spin it a little until i can use a screwdriver?(i figured the black line should be facing straight up)I think there is a small set screw on the counterweight. You have to first put the inner counterweight part on the arm, and then the outer (larger) CW over that. I got my 707 without a counterweight at first, and jerry-rigged something with an old brass plumbing fitting. I'll look at mine if you want, and run you through it. Let me know.
Nice table!
Has anyone experienced balance issues with the grace? It seems as it will not balance unless the inner screw is loosened and the inner sleeve is slid back a bit on the arm. The weight unscrewed itself doesn't have enough weight.
Ugh i need more help. I’m trying to play my first record and the arm wants to keep returning back off the platter. The anti skate is set to zero on the grace. when the counterweight is increased it seems like it might start to stay on the record but it is way too heavy off the record. Any suggestions??
